Was du brauchst
Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
Remove the three 1mm Phillips #0 screws surrounding the fan.
Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to carefully unplug the fan connector.
Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
4 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
