Zum Hauptinhalt wechseln
Sony WH-1000XM3 Earpad Foam Screens Replacement
Was du brauchst
  1. Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove earcup cushions: Schritt 1, Bild 1 von 3 Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove earcup cushions: Schritt 1, Bild 2 von 3 Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove earcup cushions: Schritt 1, Bild 3 von 3
    • Before beginning, turn off the headphones
    • For more information, see Sony WH-1000XM3 Earcup Cushion Replacement
    • Insert a plastic spudger between the cushion and the earcup frame
    • There are six clips that hold the cushion in place, release them moving the spudger around the frame
  2. Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove old foam screens: Schritt 2, Bild 1 von 2 Sony WH-1000XM3 Earpad Foam Screens Replacement, Remove old foam screens: Schritt 2, Bild 2 von 2
    • Gently pull away right and lef foam screen
    • Screens are made by three pieces glued together, leverage on the ones glued to the earpad to avoid damaging the old screens (you will need them as reference for the tape placement)
  3. Sony WH-1000XM3 Earpad Foam Screens Replacement, Prepare new screens: Schritt 3, Bild 1 von 1
    • Cut double-sided tape and place it in the same position of the old screens
    • Right and left screens are not identical and have different tape placement
  4. Sony WH-1000XM3 Earpad Foam Screens Replacement, Install new screens: Schritt 4, Bild 1 von 1
    • Remove tape cover and place new screens in position
    • In the right earcup there is a hole (in red), DO NOT COVER IT with the screen
Abschluss
Once installed the new screens, reinstall earpad
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
dinoo_fixit
987 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 37
Letzte 30 Tage: 195
Insgesamt: 846
