Einleitung
By following this repair guide, you will be able to replace the full Head Display; thus, providing yourself with better visuals and imaging.
Was du brauchst
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
Pull the USB cable off of the back plate.
Disconnect the display power cable from the motherboard.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
Use a spudger to gently lift the motherboard up and out of the radio.
Remove the four 3.5mm Phillips #0 screws from the sides of the display.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Where do you get a replacement screen?
I need one for a xav 3005 db
Thank you very much for this great write up.
However after having performed it, if all you are doing is replacing the screen, then steps 1, 4, 5 and 7 are actually completely unnecessary . There is no need to remove the back panel or the motherboard.
but thank you nonetheless for having shown the way.
I need to get a replacement screen for a Sony xav 1500 any idea of a cheap place?
