Zum Hauptinhalt wechseln
Sony XAV-AX100 Motherboard Replacement
Was du brauchst
  1. Sony XAV-AX100 Motherboard Replacement, USB Cable: Schritt 1, Bild 1 von 3 Sony XAV-AX100 Motherboard Replacement, USB Cable: Schritt 1, Bild 2 von 3 Sony XAV-AX100 Motherboard Replacement, USB Cable: Schritt 1, Bild 3 von 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Motherboard Replacement: Schritt 2, Bild 1 von 2 Sony XAV-AX100 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Motherboard Replacement: Schritt 5, Bild 1 von 3 Sony XAV-AX100 Motherboard Replacement: Schritt 5, Bild 2 von 3 Sony XAV-AX100 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 Sony XAV-AX100 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Motherboard Replacement: Schritt 7, Bild 1 von 3 Sony XAV-AX100 Motherboard Replacement: Schritt 7, Bild 2 von 3 Sony XAV-AX100 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
Abschluss
USF Tampa, Team S1-G5, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Where to buy the motherboard ?
B.Keat - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 1,567
