Zum Hauptinhalt wechseln
Sony Xperia XA1 Rear Camera Replacement
Was du brauchst
  1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: Schritt 1, Bild 1 von 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: Schritt 1, Bild 2 von 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: Schritt 1, Bild 3 von 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: Schritt 2, Bild 1 von 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: Schritt 2, Bild 2 von 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: Schritt 2, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws near the top of the phone.
    • Use a spudger to gently pry the three tabs at the top of the phone.
  3. Sony Xperia XA1 Rear Camera Replacement: Schritt 3, Bild 1 von 3 Sony Xperia XA1 Rear Camera Replacement: Schritt 3, Bild 2 von 3 Sony Xperia XA1 Rear Camera Replacement: Schritt 3, Bild 3 von 3
    • Gently pry at the tabs until the cover comes free and is able to be removed.
    • Pull the piece up and set it aside. No cables are attached to the back.
  4. Sony Xperia XA1 Rear Camera Replacement: Schritt 4, Bild 1 von 3 Sony Xperia XA1 Rear Camera Replacement: Schritt 4, Bild 2 von 3 Sony Xperia XA1 Rear Camera Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool to release the back camera connector.
    • Gently pull the camera connector up to remove it.
    • Exercise caution when handling the rubber holder around the lens, as it can pop off easily.
Abschluss
sebastianh034
253 Reputation
3 Anleitungen geschrieben
Utah Tech University, Team 1-4, McMurrin Spring 2023 Mitglied von Utah Tech University, Team 1-4, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G4
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 20
Insgesamt: 184
