Zum Hauptinhalt wechseln
Sony Xperia XA1 Screen Replacement
Was du brauchst
  1. Sony Xperia XA1 Screen Replacement, Phone Back Cover: Schritt 1, Bild 1 von 3 Sony Xperia XA1 Screen Replacement, Phone Back Cover: Schritt 1, Bild 2 von 3 Sony Xperia XA1 Screen Replacement, Phone Back Cover: Schritt 1, Bild 3 von 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
    Frag FixBot
    Kommentar hinzufügen
  2. Sony Xperia XA1 Screen Replacement, Speaker: Schritt 2, Bild 1 von 3 Sony Xperia XA1 Screen Replacement, Speaker: Schritt 2, Bild 2 von 3 Sony Xperia XA1 Screen Replacement, Speaker: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
    Frag FixBot
  3. Sony Xperia XA1 Screen Replacement: Schritt 3, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 3, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 3, Bild 3 von 3
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
    Frag FixBot
  4. Sony Xperia XA1 Screen Replacement: Schritt 4, Bild 1 von 2 Sony Xperia XA1 Screen Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
    Frag FixBot
  5. Sony Xperia XA1 Screen Replacement: Schritt 5, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 5, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 5, Bild 3 von 3
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
    Frag FixBot
  6. Sony Xperia XA1 Screen Replacement, USB-C Module: Schritt 6, Bild 1 von 3 Sony Xperia XA1 Screen Replacement, USB-C Module: Schritt 6, Bild 2 von 3 Sony Xperia XA1 Screen Replacement, USB-C Module: Schritt 6, Bild 3 von 3
    • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
    • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
    Frag FixBot
  7. Sony Xperia XA1 Screen Replacement: Schritt 7, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 7, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 7, Bild 3 von 3
    • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
    • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
    Frag FixBot
  8. Sony Xperia XA1 Screen Replacement, Screen: Schritt 8, Bild 1 von 3 Sony Xperia XA1 Screen Replacement, Screen: Schritt 8, Bild 2 von 3 Sony Xperia XA1 Screen Replacement, Screen: Schritt 8, Bild 3 von 3
    • Using a spudger, carefully remove the thin copper piece attached to the motherboard.
    • This part is very easy to damage and can not be reused if damaged too much.
    Frag FixBot
  9. Sony Xperia XA1 Screen Replacement: Schritt 9, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 9, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 9, Bild 3 von 3
    • Carefully remove the front-facing camera with a spudger or your fingers.
    Frag FixBot
  10. Sony Xperia XA1 Screen Replacement: Schritt 10, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 10, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 10, Bild 3 von 3
    • Remove the single 3mm screw holding the audio jack using a Phillips #000 bit.
    • Using an iFixit Opening Tool, disconnect the audio jack from the motherboard.
    • Use a prying tool, such as a spudger, to remove the audio jack.
    Frag FixBot
  11. Sony Xperia XA1 Screen Replacement: Schritt 11, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 11, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 11, Bild 3 von 3
    • Disconnect the camera using an iFixit opening tool and remove it with your fingers.
    Frag FixBot
  12. Sony Xperia XA1 Screen Replacement: Schritt 12, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 12, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 12, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the two antennas from the motherboard using an iFixit opening tool or pair of tweezers.
    Frag FixBot
  13. Sony Xperia XA1 Screen Replacement: Schritt 13, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 13, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 13, Bild 3 von 3
    • Remove the SIM tray using your fingernail.
    • Using a spudger, remove the two connector tabs attached to the motherboard
    Frag FixBot
  14. Sony Xperia XA1 Screen Replacement: Schritt 14, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 14, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 14, Bild 3 von 3
    • Remove the single 3mm screw from the motherboard using a Phillips #000 bit.
    • Use a spudger to gently pry the motherboard free.
    Frag FixBot
  15. Sony Xperia XA1 Screen Replacement: Schritt 15, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 15, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 15, Bild 3 von 3
    • Peel the plastic battery tabs free.
    Frag FixBot
  16. Sony Xperia XA1 Screen Replacement: Schritt 16, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 16, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 16, Bild 3 von 3
    • Using a pair of angled tweezers, carefully remove the earpiece.
    • The ear piece is attached using a sticky adhesive
    Frag FixBot
  17. Sony Xperia XA1 Screen Replacement: Schritt 17, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 17, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 17, Bild 3 von 3
    • Using a pair of angled tweezers, carefully remove the small metal bracket from the top left side of the phone.
    Frag FixBot
  18. Sony Xperia XA1 Screen Replacement: Schritt 18, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 18, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 18, Bild 3 von 3
    • Remove the four 3mm silver screws located on the left side of the case using a Phillips #000 bit.
    • Once the screws are removed, unfold the side piece.
    Frag FixBot
  19. Sony Xperia XA1 Screen Replacement: Schritt 19, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 19, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 19, Bild 3 von 3
    • Using a pair of angled tweezers, remove the power and volume buttons.
    Frag FixBot
  20. Sony Xperia XA1 Screen Replacement: Schritt 20, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 20, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 20, Bild 3 von 3
    • Carefully remove the antennas.
    • Use a pair of tweezers if needed.
    Frag FixBot
  21. Sony Xperia XA1 Screen Replacement: Schritt 21, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 21, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 21, Bild 3 von 3
    • Remove the four 3mm silver screws from the right side of the phone using a Phillips #000 bit.
    • Once unfolded, peel the side piece from the phone, separating the glue that holds the two pieces together.
    Frag FixBot
  22. Sony Xperia XA1 Screen Replacement: Schritt 22, Bild 1 von 3 Sony Xperia XA1 Screen Replacement: Schritt 22, Bild 2 von 3 Sony Xperia XA1 Screen Replacement: Schritt 22, Bild 3 von 3
    • Remove the other side in the same manner.
    • All removeable components should be free, ready to be installed into your replacement screen.
    Frag FixBot
Abschluss
Hunter
349 Reputation
2 Anleitungen geschrieben
Utah Tech University, Team 1-4, McMurrin Spring 2023 Mitglied von Utah Tech University, Team 1-4, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G4
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 93
Insgesamt: 892
