Einleitung
This guide is for the replacement of the screen for the Sony Xperia XA1.
If your phone screen is cracked and you're unable use your phone or if you want it to look newer then this guide will help you get a new crack-free screen.
This replacement may also fix the touch issues many users experience with this phone. Be sure to go through the troubleshooting page before proceeding to this guide to determine whether you need to replace the screen. However, make sure you've tried all other methods of troubleshooting, as a screen replacement requires you to disassemble and remove all other components in the phone.
Was du brauchst
Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
Use a plastic opening tool to lift the battery connector.
Lift the flaps on both sides of the battery.
Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
Once the piece is loose, use your hand to remove the speaker from the phone.
Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
Using a spudger, carefully remove the thin copper piece attached to the motherboard.
Remove the single 3mm screw holding the audio jack using a Phillips #000 bit.
Using an iFixit Opening Tool, disconnect the audio jack from the motherboard.
Use a prying tool, such as a spudger, to remove the audio jack.
Disconnect the camera using an iFixit opening tool and remove it with your fingers.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the two antennas from the motherboard using an iFixit opening tool or pair of tweezers.
Remove the SIM tray using your fingernail.
Using a spudger, remove the two connector tabs attached to the motherboard
Remove the single 3mm screw from the motherboard using a Phillips #000 bit.
Use a spudger to gently pry the motherboard free.
Using a pair of angled tweezers, carefully remove the small metal bracket from the top left side of the phone.
Remove the four 3mm silver screws located on the left side of the case using a Phillips #000 bit.
Once the screws are removed, unfold the side piece.
Remove the four 3mm silver screws from the right side of the phone using a Phillips #000 bit.
Once unfolded, peel the side piece from the phone, separating the glue that holds the two pieces together.
