Einleitung
This is a replacement guide for the Sony Xperia XA1 speaker.
Before using this guide, be sure to check out the troubleshooting page to ensure the speaker needs to be replaced.
Was du brauchst
Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
Use a plastic opening tool to lift the battery connector.
Lift the flaps on both sides of the battery.
Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
Once the piece is loose, use your hand to remove the speaker from the phone.
