Zum Hauptinhalt wechseln
Sony Xperia Z1 - Password Removal, Firmware update with PC Companion
Einführungsvideo
  1. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 1, Bild 1 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 1, Bild 2 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 1, Bild 3 von 3
  2. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 2, Bild 1 von 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 2, Bild 2 von 2
    • Insert wisdom here.
  3. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 3, Bild 1 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 3, Bild 2 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 3, Bild 3 von 3
    • From here you can update your device firmware but it must be unlocked (device can't be in lock screen).
    • Start the new PC Companion function "Support Zone".
    • PC Companion will download some necessary files and you are ready to start "Phone / Tablet Software Update".
  4. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 4, Bild 1 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 4, Bild 2 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 4, Bild 3 von 3
    • Your laptop must be connected to the power adapter.
    • Select "repair my phone / tablet".
    • The last warning for your personal data
  5. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 5, Bild 1 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 5, Bild 2 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 5, Bild 3 von 3
    • After PC Companion prepared your laptop for the update, you must choose the model of your device.
    • The battery must be at last 80% charged.
    • Doesn't make a mistake in choosing the model.
  6. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 6, Bild 1 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 6, Bild 2 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 6, Bild 3 von 3
    • Switch of the phone. If you have a problem with the Android OS and you can't switch it off, then press and hold the power on button for a long time, or use the reset button under the micro SIM cover.
    • Press and hold the volume down button and then insert the micro USB cable.
    • Your PC will recognize the phone and PC Companion will download the latest version for your device and will flash it.
  7. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 7, Bild 1 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 7, Bild 2 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 7, Bild 3 von 3
    • If your PC doesn't recognize you phone (SOMC Flash Device), you must install drivers for it.
    • S1Boot Fasboot drivers
  8. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 8, Bild 1 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 8, Bild 2 von 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: Schritt 8, Bild 3 von 3
    • When PC Companion finished updating, disconnect the phone and switch it on.
    • Your device is with latest firmware, in factory state, without personal data and security.
    • Please SUBSCRIBE to my channel ツ
Abschluss
19 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.308 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.533 Anleitungen geschrieben
3 Kommentare
Thank you, this was really helpful.
DOWNLOAD AND UPDATE FIRMWARE SONY XPERIA XZ 601SO gofirmware
Jacky888 Jacky888 - Antwort
Great platform to unlock my device.
get Offline Freeware Software’s
Offline Freewarefiles - Antwort
which version is it? sony companion doesnt let you do it in latest. plz reply
DcKnown by Public - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 21,093
