Zum Hauptinhalt wechseln
Sony Xperia Z1s Motherboard Replacement
Was du brauchst
  1. Sony Xperia Z1s Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
  2. Sony Xperia Z1s Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
  5. Sony Xperia Z1s Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
  6. Sony Xperia Z1s Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
  7. Sony Xperia Z1s Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
  8. Sony Xperia Z1s Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
  9. Sony Xperia Z1s Motherboard Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
  10. Sony Xperia Z1s Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Clemson, Team 4-4, Hunter Fall 2021 Mitglied von Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 361
