Zum Hauptinhalt wechseln
Sony Xperia Z1s Screen Replacement
Was du brauchst
  1. Sony Xperia Z1s Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
    Frag FixBot
    Kommentar hinzufügen
  2. Sony Xperia Z1s Screen Replacement: Schritt 2, Bild 1 von 1
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
    Frag FixBot
  3. Sony Xperia Z1s Screen Replacement: Schritt 3, Bild 1 von 1
    • Use the opening pick to pry off the battery flex cable.
    Frag FixBot
  4. Sony Xperia Z1s Screen Replacement: Schritt 4, Bild 1 von 1
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
    Frag FixBot
  5. Sony Xperia Z1s Screen Replacement: Schritt 5, Bild 1 von 1
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
    Frag FixBot
  6. Sony Xperia Z1s Screen Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
    Frag FixBot
  7. Sony Xperia Z1s Screen Replacement: Schritt 7, Bild 1 von 1
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
    Frag FixBot
  8. Sony Xperia Z1s Screen Replacement: Schritt 8, Bild 1 von 1
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
    Frag FixBot
  9. Sony Xperia Z1s Screen Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
    Frag FixBot
  10. Sony Xperia Z1s Screen Replacement: Schritt 10, Bild 1 von 1
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
    Frag FixBot
  11. Sony Xperia Z1s Screen Replacement, LCD Screen: Schritt 11, Bild 1 von 1
    • Using the T4 Torx screwdriver, unscrew the single 5 mm screw from the bottom left corner of the loudspeaker cover.
    Frag FixBot
  12. Sony Xperia Z1s Screen Replacement: Schritt 12, Bild 1 von 1
    • Slide the opening pick under the edge of the loudspeaker cover.
    • Gently lift and pry up the loudspeaker cover.
    Frag FixBot
  13. Sony Xperia Z1s Screen Replacement: Schritt 13, Bild 1 von 1
    • Use your fingers to slowly peel back the black flex cable in the middle of the phone until it is only connected at the bottom of the phone.
    Frag FixBot
  14. Sony Xperia Z1s Screen Replacement: Schritt 14, Bild 1 von 1
    • Gently slide the opening pick underneath the screen.
    • Lift the opening pick upward to remove the screen.
    • If needed, use a heat gun to loosen the adhesive holding the screen by aiming it around the edge of the screen.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Clemson, Team 4-4, Hunter Fall 2021 Mitglied von Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 572
