Einleitung
If Robot’s internal battery does not hold a charge, follow this guide to replace the battery. You will need a Size 00 Philips Screwdriver to complete replacement guide.
Was du brauchst
Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
Lift the top panel away from the main body of the robot to expose the yellow battery.
Insert index finger in between battery and plastic shell of robot, and push battery out of the battery holder toward the wire.
Now that the battery is completely removed, additional efforts, like soldering the wires off, must be taken to replace the battery.
2 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Any tips on where to buy a replacement battery?
In fact it’s easy, was able to put 1000 mah Lipo 952540 with a little stretching of battery plastic holder
can we replace boxer’s USB slot?
