Zum Hauptinhalt wechseln
Spin Master Boxer Robot Speaker Replacement
Was du brauchst
  1. Spin Master Boxer Robot Speaker Replacement, Robot Screen: Schritt 1, Bild 1 von 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Speaker Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Speaker Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Speaker Replacement: Schritt 4, Bild 1 von 2 Spin Master Boxer Robot Speaker Replacement: Schritt 4, Bild 2 von 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Speaker Replacement, Robot Speaker: Schritt 6, Bild 1 von 2 Spin Master Boxer Robot Speaker Replacement, Robot Speaker: Schritt 6, Bild 2 von 2
    • Using a Phillips #00 screwdriver, unscrew the two 3mm screws connecting the black speaker cover to the top panel.
  7. Spin Master Boxer Robot Speaker Replacement: Schritt 7, Bild 1 von 1
Abschluss
Lauren Roide
739 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G1, Maness Spring 2019 Mitglied von Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 992
