Zum Hauptinhalt wechseln
Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement
Was du brauchst
  1. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: Schritt 1, Bild 1 von 2 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: Schritt 1, Bild 2 von 2
    • Remove the six silver 11.4 mm Phillips #0 screws
    • Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Styrofoam Pad: Schritt 2, Bild 1 von 1
    • Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
    • Do this carefully to avoid tearing the pad.
  3. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: Schritt 3, Bild 1 von 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: Schritt 3, Bild 2 von 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: Schritt 3, Bild 3 von 3
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
  4. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: Schritt 4, Bild 1 von 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: Schritt 4, Bild 2 von 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: Schritt 4, Bild 3 von 3
    • Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
    • Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
  5. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Un-Soldering the Wires: Schritt 5, Bild 1 von 1
Abschluss
Andrew Gittens
143 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 4-5, Brown Fall 2014 Mitglied von USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Mitglieder
6 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where do you get the replacement parts?
clsutliff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 575
