Zum Hauptinhalt wechseln
SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement
Was du brauchst
  1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: Schritt 1, Bild 1 von 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: Schritt 1, Bild 2 von 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: Schritt 1, Bild 3 von 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 2, Bild 1 von 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 3, Bild 1 von 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 3, Bild 2 von 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 4, Bild 1 von 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 4, Bild 2 von 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 5, Bild 1 von 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 6, Bild 1 von 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: Schritt 6, Bild 2 von 2
    • Desolder the four button pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on Wie man Lötverbindungen herstellt und entlötet.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle Chang
1.152 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S18-G1, White Winter 2019 Mitglied von Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 1,134
