Zum Hauptinhalt wechseln
SuperSonic Matrix Mid SC-999 Battery Replacement
Was du brauchst
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      Frag FixBot
      Kommentar hinzufügen
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: Schritt 2, Bild 1 von 1
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      Frag FixBot
    3. SuperSonic Matrix Mid SC-999 Battery Replacement: Schritt 3, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Battery Replacement: Schritt 3, Bild 2 von 2
      • Lift the back cover from the body of the device to expose the internal components.
      Frag FixBot
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: Schritt 4, Bild 1 von 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: Schritt 4, Bild 2 von 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: Schritt 4, Bild 3 von 3
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
      Frag FixBot
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: Schritt 5, Bild 1 von 3 SuperSonic Matrix Mid SC-999 Battery Replacement: Schritt 5, Bild 2 von 3 SuperSonic Matrix Mid SC-999 Battery Replacement: Schritt 5, Bild 3 von 3
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Baylor, Team 6-1, Shaver Spring 2015 Mitglied von Baylor, Team 6-1, Shaver Spring 2015
BU-SHAVER-S15S6G1
4 Mitglieder
27 Anleitungen geschrieben
1 Kommentar zur Anleitung
Link to the soldering technique guide!
Josh Lewis - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 2,731
