Zum Hauptinhalt wechseln
SuperSonic Matrix Mid SC-999 Headphone Jack Replacement
Was du brauchst
  1. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: Schritt 3, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Headphone Jack: Schritt 4, Bild 1 von 1
    • Locate the headphone jack on the device.
  5. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: Schritt 5, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: Schritt 5, Bild 2 von 2
    • Desolder the 5 soldered connections (marked in red) that connect the headphone jack to the device.
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot, so be mindful in your handling.
Abschluss
Harris Dagha
866 Reputation
7 Anleitungen geschrieben
Dr Shaverz boyz Mitglied von Dr Shaverz boyz
Community
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 341
