Zum Hauptinhalt wechseln
SuperSonic Matrix Mid SC-999 Microphone Replacement
Was du brauchst
  1. SuperSonic Matrix Mid SC-999 Microphone Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Microphone Replacement: Schritt 3, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Microphone Replacement: Schritt 3, Bild 2 von 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Microphone Replacement, Microphone: Schritt 4, Bild 1 von 1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  5. SuperSonic Matrix Mid SC-999 Microphone Replacement: Schritt 5, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Microphone Replacement: Schritt 5, Bild 2 von 2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
Abschluss
Harris Dagha
866 Reputation
7 Anleitungen geschrieben
Dr Shaverz boyz Mitglied von Dr Shaverz boyz
Community
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 155
