Zum Hauptinhalt wechseln
SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement
Was du brauchst
  1. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 3, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: Schritt 4, Bild 1 von 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: Schritt 4, Bild 2 von 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Battery: Schritt 4, Bild 3 von 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 5, Bild 1 von 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 5, Bild 2 von 3 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 5, Bild 3 von 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 6, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 6, Bild 2 von 2
    • Remove the two Phillips #00 screws attaching the housing of the camera to the device.
  7. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 7, Bild 1 von 1
    • With the screws removed you should easily be able to remove the camera unit.
  8. SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 8, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Rear Facing Camera Replacement: Schritt 8, Bild 2 von 2
    • Follow the camera unit back to the motherboard.
    • Use the spudger tool to remove the camera.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Dr Shaverz boyz Mitglied von Dr Shaverz boyz
Community
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 394
