Einleitung
In this guide you will open the back cover and use a screwdriver to remove the camera from its housing.
Was du brauchst
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
Again, you will hear a snapping sound as the cover is separated from the body of the device.
Lift the back cover from the body of the device to expose the internal components.
Remove the Battery
The battery is secured to the back panel with tape and glue.
Peel back the tape around the battery and discard it.
Tear through the adhesive holding the battery by using the spudger tool.
Desolder the 2 Battery Wires
The Battery has two wires connected to the motherboard (one black and one red).
Remove the two Phillips #00 screws attaching the housing of the camera to the device.
Follow the camera unit back to the motherboard.
Use the spudger tool to remove the camera.
Eine weitere Person hat diese Anleitung absolviert.
