Zum Hauptinhalt wechseln
SuperSonic Matrix Mid SC-999 Speaker Replacement
Was du brauchst
  1. SuperSonic Matrix Mid SC-999 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Speaker Replacement: Schritt 3, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
  5. SuperSonic Matrix Mid SC-999 Speaker Replacement: Schritt 5, Bild 1 von 2 SuperSonic Matrix Mid SC-999 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
Abschluss
Johncy George
101 Reputation
1 Anleitung geschrieben
Baylor, Team 6-1, Shaver Spring 2015 Mitglied von Baylor, Team 6-1, Shaver Spring 2015
BU-SHAVER-S15S6G1
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 303
