Zum Hauptinhalt wechseln
Supersonic Matrix SC-91MID Speakers Replacement
Was du brauchst
  1. Supersonic Matrix SC-91MID Speakers Replacement, Back cover: Schritt 1, Bild 1 von 1
    • Use an opening tool to separate the back cover of the tablet by wedging the tool into the crease between the back cover and touchscreen.
    • Work your way around the perimeter of the tablet to detach the back cover and remove it carefully so you don't rip any cables attached.
  2. Supersonic Matrix SC-91MID Speakers Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to carefully disconnect the display ribbons from the motherboard.
  3. Supersonic Matrix SC-91MID Speakers Replacement: Schritt 3, Bild 1 von 1
    • To remove the battery, use the spudger to pry the battery up and away from the tablet.
    • You might have some difficulty removing due to glue holding the battery in place.
    • Work your way around the perimeter of the battery with the spudger or opening picks gently so you don't bend or puncture the battery.
  4. Supersonic Matrix SC-91MID Speakers Replacement: Schritt 4, Bild 1 von 2 Supersonic Matrix SC-91MID Speakers Replacement: Schritt 4, Bild 2 von 2
    • Use a spudger to remove the speakers.
    • To remove the motherboard, remove the three screws that hold the board in place with a Phillips screwdriver.
  5. Supersonic Matrix SC-91MID Speakers Replacement, Speakers: Schritt 5, Bild 1 von 1
    • Desolder the four speaker wires connecting the speaker to the motherboard using a soldering station.
    • If you're unfamiliar with soldering or desoldering check out this guide Wie man Lötverbindungen herstellt und entlötet
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    • The tool in the picture is not required for this step. It is just being used to point out the wires.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Texas Tech, Team S46-G4, Bennett Spring 2017 Mitglied von Texas Tech, Team S46-G4, Bennett Spring 2017
TTU-BENNETT-S17S46G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 306
