Einleitung
To replace other components in the Swagtron T3, you will need to first remove the outer shell by removing the screws. Make sure to take note of where each type of screw goes to streamline the process of putting it back together. To avoid electric shock, discharge the capacitors using the capacitor discharge tool before making any changes to your Swagtron. Click here to learn how to safely discharge a capacitor.
Was du brauchst
Flip the Swagtron so that the footpads are facing the ground.
Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
Slowly lift the backside cover.
Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
Three cables on the motherboard side.
Two red cables with white connectors and one white cable with a white connector.
One yellow cable with a black connector on the battery side.
