Zum Hauptinhalt wechseln
Swann Wi-Fi Indoor Security Camera Infrared LED Replacement
Was du brauchst
  1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: Schritt 1, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: Schritt 1, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: Schritt 1, Bild 3 von 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: Schritt 2, Bild 1 von 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Infrared LED: Schritt 4, Bild 1 von 1
    • Facing the inside of the front case, unscrew the three 2.0 mm Phillips #0 black screws located on the back of the LED ring.
  5. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: Schritt 5, Bild 1 von 2 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: Schritt 5, Bild 2 von 2
    • Release the clip connection connecting the LED ring to the motherboard.
    • Remove the infrared LED assembly.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 1,074
