Zum Hauptinhalt wechseln
Swann Wi-Fi Indoor Security Camera Microphone Replacement
Was du brauchst
  1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: Schritt 1, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: Schritt 1, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: Schritt 1, Bild 3 von 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Microphone Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: Schritt 4, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: Schritt 4, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: Schritt 4, Bild 3 von 3
    • Locate microphone and pull to dislodge from the holder.
    • Disconnect the connector located on the main board to finish disconnecting the microphone.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 746
