Zum Hauptinhalt wechseln
Swann Wi-Fi Indoor Security Camera SD Card Replacement
Was du brauchst
  1. Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: Schritt 1, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: Schritt 1, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, Case: Schritt 1, Bild 3 von 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera SD Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera SD Card Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: Schritt 4, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: Schritt 4, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera SD Card Replacement, SD Card: Schritt 4, Bild 3 von 3
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
  5. Swann Wi-Fi Indoor Security Camera SD Card Replacement: Schritt 5, Bild 1 von 1
    • With the motherboard removed, flip it over and remove the SD card by pushing in the SD card, releasing it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 31
Insgesamt: 1,241
