Zum Hauptinhalt wechseln
Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement
Was du brauchst
  1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: Schritt 1, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: Schritt 1, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: Schritt 1, Bild 3 von 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: Schritt 2, Bild 1 von 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: Schritt 4, Bild 1 von 2 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: Schritt 4, Bild 2 von 2
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
    • Release the four camera cable connections on the motherboard.
  5. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: Schritt 5, Bild 1 von 1
    • Facing the back of the motherboard, remove the two 2.0 mm Phillips #0 screws connecting the camera to the motherboard.
Abschluss
Ein Kommentar
is there a place i can buy a replacement lens for my swann security camera please
sn 10050062001244
Sonny Jobe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 31
Insgesamt: 1,087
