Zum Hauptinhalt wechseln
System76 Serval WS Cooling Fan Replacement
Was du brauchst
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: Schritt 1, Bild 1 von 1
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: Schritt 2, Bild 1 von 2 System76 Serval WS Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: Schritt 4, Bild 1 von 2 System76 Serval WS Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Abschluss
Oliver Anderson
289 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G4, Valliere Spring 2019 Mitglied von UMass Dartmouth, Team S1-G4, Valliere Spring 2019
UMASSD-VALLIERE-S19S1G4
4 Mitglieder
Ein Kommentar
What model of fan would one buy to replace this?
CrustyTrombone - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 627
