Zum Hauptinhalt wechseln
TMY V08 Speaker Replacement
Was du brauchst
  1. TMY V08 Speaker Replacement, Top Panel: Schritt 1, Bild 1 von 3 TMY V08 Speaker Replacement, Top Panel: Schritt 1, Bild 2 von 3 TMY V08 Speaker Replacement, Top Panel: Schritt 1, Bild 3 von 3
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Speaker Replacement: Schritt 2, Bild 1 von 3 TMY V08 Speaker Replacement: Schritt 2, Bild 2 von 3 TMY V08 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 3 TMY V08 Speaker Replacement, Speaker: Schritt 3, Bild 2 von 3 TMY V08 Speaker Replacement, Speaker: Schritt 3, Bild 3 von 3
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Speaker Replacement: Schritt 4, Bild 1 von 2 TMY V08 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Rotate the projector counterclockwise 90 degrees
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Speaker Replacement: Schritt 5, Bild 1 von 3 TMY V08 Speaker Replacement: Schritt 5, Bild 2 von 3 TMY V08 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Rotate the projector counterclockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Speaker Replacement: Schritt 6, Bild 1 von 3 TMY V08 Speaker Replacement: Schritt 6, Bild 2 von 3 TMY V08 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove the five 7.3 mm screws from the black cover using a Phillips #1 screwdriver.
    • Take off the right black cover, exposing the speaker.
  7. TMY V08 Speaker Replacement: Schritt 7, Bild 1 von 2 TMY V08 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Grasp the speaker firmly and lift up to remove.
Abschluss
Wesley
271 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 89
