Einleitung
This guide is used to replace the LED screen of your TOGUARD C310 Dual Dash Cam.
You must be extremely careful when removing the screen and moving other components to access it.
Was du brauchst
Use a screwdriver to remove the four corner screws on the face of the dash cam.
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
