Einleitung
If the battery will not hold any charge or if no power is going through to the device you will have to change the battery.
Was du brauchst
Remove the rubber pad from the bottom of the device by using the nylon spudger to pry the glue holding it together. Then use the spudger to remove the rubber pad.
Unscrew the four 6mm screws located under pad using the PH0 screwdriver head and lift plastic cover using the nylon spudger. Be careful not to sever the wire that leads to the circuit board.
Use the nylon spudger and the plastic opening tool to lift up the battery from the casing. Use the spudger on one side and the plastic opening tool on the other.
To remove battery, cut the wires that connect to the battery.
To reconnect battery, solder wires back onto new battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
What is battery spec and how can i get one?
Mike
Does anyone know how to convert this to direct USB power or power adapter? I know that I can charge it using USB, but I think the battery in my unit is almost dead because it doesn’t last long. If I keep it plugged to USB while using it, it turns off after some time, again probably because of the bad battery.
I appreciate the information but in THIS case it is mot worth the expense and effort to refurbish a $25 unit. Thank again for the effort
