Einleitung
Teddy Ruxpin’s eyes are LED and will react to story-time. If the eyes are glitching, not turning on, or malfunctioning in any way, follow this guide to replace them. Be cautious during desoldering and keep track of screws. Refer to the desoldering guide for help.
Was du brauchst
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
Remove the interior of the doll.
Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
Once those wires are disconnected, desolder the wires connected from the eye motherboard.
2 weitere Personen haben diese Anleitung absolviert.
