Einleitung
Many of the Teddy Ruxpin’s parts are all controlled by the main motherboard. If an issue with your bear boils down to more than just a replaceable part, it may be time to replace the motherboard. Desoldering is required, so be sure to refer to the desoldering guide. You will also need to use a Phillips #1 screwdriver to access the motherboard.
Was du brauchst
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
Remove the interior of the doll.
Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
Once those wires are disconnected, desolder the wires connected from the eye motherboard.
Remove five 12.5mm Phillips #1 screws.
Pull the mouth mechanism out of the shell.
Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
Open the mouth mechanism
Remove the two 12.5 MM Phillips #1 screws holding the main motherboard into place.
