Einleitung
If your Teddy Ruxpin’s mouth is not moving correctly or seems like it is malfunctioning, this replacement guide will help you fix your Teddy Ruxpin. The mouth should move along with storytime as audio is playing through the speaker. This guide will include desoldering and unscrewing, so be sure to utilize the iFixit desoldering guide while replacing this part as well as the other prerequisite guides.
Was du brauchst
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
Remove the interior of the doll.
Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
Once those wires are disconnected, desolder the wires connected from the eye motherboard.
Remove five 12.5mm Phillips #1 screws.
Pull the mouth mechanism out of the shell.
Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
Open the mouth mechanism
