Zum Hauptinhalt wechseln
Teddy Ruxpin Speaker Replacement
Was du brauchst
  1. Teddy Ruxpin Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Teddy Ruxpin Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Speaker Replacement: Schritt 2, Bild 1 von 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Speaker Replacement, Arms: Schritt 4, Bild 1 von 3 Teddy Ruxpin Speaker Replacement, Arms: Schritt 4, Bild 2 von 3 Teddy Ruxpin Speaker Replacement, Arms: Schritt 4, Bild 3 von 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Speaker Replacement: Schritt 5, Bild 1 von 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Speaker Replacement: Schritt 6, Bild 1 von 3 Teddy Ruxpin Speaker Replacement: Schritt 6, Bild 2 von 3 Teddy Ruxpin Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Speaker Replacement: Schritt 7, Bild 1 von 2 Teddy Ruxpin Speaker Replacement: Schritt 7, Bild 2 von 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Speaker Replacement: Schritt 8, Bild 1 von 2 Teddy Ruxpin Speaker Replacement: Schritt 8, Bild 2 von 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Speaker Replacement: Schritt 9, Bild 1 von 1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Speaker Replacement, Housing Cover: Schritt 10, Bild 1 von 3 Teddy Ruxpin Speaker Replacement, Housing Cover: Schritt 10, Bild 2 von 3 Teddy Ruxpin Speaker Replacement, Housing Cover: Schritt 10, Bild 3 von 3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Speaker Replacement, Speaker: Schritt 11, Bild 1 von 2 Teddy Ruxpin Speaker Replacement, Speaker: Schritt 11, Bild 2 von 2
    • Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
  12. Teddy Ruxpin Speaker Replacement: Schritt 12, Bild 1 von 1
    • Desolder the wire from the speaker and replace.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jayin Patel
406 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S18-G5, White Winter 2020 Mitglied von Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 711
