Zum Hauptinhalt wechseln
Teenage Engineering OP-Z Volume Potentiometer Replacement
Was du brauchst
  1. Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: Schritt 1, Bild 1 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: Schritt 1, Bild 2 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
    Frag FixBot
    Kommentar hinzufügen
  2. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 2, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 2, Bild 2 von 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
    Frag FixBot
  3. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 3, Bild 1 von 1
    • Remove the bottom plate including the rubber feet.
    Frag FixBot
  4. Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: Schritt 4, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
    Frag FixBot
  5. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 5, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
    Frag FixBot
  6. Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: Schritt 6, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: Schritt 6, Bild 2 von 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
    Frag FixBot
  7. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 7, Bild 1 von 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
    Frag FixBot
  8. Teenage Engineering OP-Z Volume Potentiometer Replacement, Midframe: Schritt 8, Bild 1 von 1
    • Remove the five Torx T4 screws.
    Frag FixBot
  9. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 9, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 9, Bild 2 von 2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
    Frag FixBot
  10. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 10, Bild 1 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 10, Bild 2 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 10, Bild 3 von 3
    • Flip the midframe over to gain access to the flex cable connector underneath.
    Frag FixBot
  11. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 11, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 11, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
    Frag FixBot
  12. Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: Schritt 12, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: Schritt 12, Bild 2 von 2
    • Use a spudger to disconnect the highway flex cable from the DSP board.
    Frag FixBot
  13. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 13, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 13, Bild 2 von 2
    • Use the spudger to disconnect the flex cable from the encoder board.
    Frag FixBot
  14. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 14, Bild 1 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 14, Bild 2 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 14, Bild 3 von 3
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
    Frag FixBot
  15. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 15, Bild 1 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 15, Bild 2 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 15, Bild 3 von 3
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
    Frag FixBot
  16. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 16, Bild 1 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 16, Bild 2 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 16, Bild 3 von 3
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
    Frag FixBot
  17. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 17, Bild 1 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 17, Bild 2 von 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 17, Bild 3 von 3
    • Peel the highway flex cable off the midframe and remove it.
    Frag FixBot
  18. Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: Schritt 18, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: Schritt 18, Bild 2 von 2
    • Use one arm of a tweezer to lift the small black flap of the ZIF connector.
    Frag FixBot
  19. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 19, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 19, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector.
    • When reassembling make sure to insert the flex cable all the way.
    Frag FixBot
  20. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 20, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 20, Bild 2 von 2
    • Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
    Frag FixBot
  21. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 21, Bild 1 von 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 21, Bild 2 von 2
    • Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
    • The volume pot is slightly glued down.
    Frag FixBot
  22. Teenage Engineering OP-Z Volume Potentiometer Replacement: Schritt 22, Bild 1 von 1
    • Remove the volume potentiometer.
    Frag FixBot
Abschluss
Tobias Isakeit
134.123 Reputation
189 Anleitungen geschrieben
Tobias Isakeit - Repairability Engineer Mitglied von Tobias Isakeit - Repairability Engineer
Business
1 Mitglied
1.161 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 30
Letzte 30 Tage: 79
Insgesamt: 1,879
