Zum Hauptinhalt wechseln
Tefal Thick N Thin Toaster 815032 Side Panels Replacement
Was du brauchst
  1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: Schritt 1, Bild 1 von 3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: Schritt 1, Bild 2 von 3 Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: Schritt 1, Bild 3 von 3
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: Schritt 2, Bild 1 von 1
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: Schritt 3, Bild 1 von 2 Tefal Thick N Thin Toaster 815032 Side Panels Replacement: Schritt 3, Bild 2 von 2
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
Abschluss
Kristen Gismondi
82.722 Reputation
202 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.433 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 192
