Zum Hauptinhalt wechseln
The Sharper Image Literati Tablet Screen Replacement
Was du brauchst
  1. The Sharper Image Literati Tablet Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet Screen Replacement: Schritt 2, Bild 1 von 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Screen Replacement: Schritt 3, Bild 1 von 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Screen Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet Screen Replacement, SD Port: Schritt 5, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet Screen Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet Screen Replacement: Schritt 8, Bild 1 von 1
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet Screen Replacement: Schritt 9, Bild 1 von 1
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet Screen Replacement: Schritt 12, Bild 1 von 1
    • Remove the silver backing plate and the adhered SD port chip.
  13. The Sharper Image Literati Tablet Screen Replacement, Screen: Schritt 13, Bild 1 von 3 The Sharper Image Literati Tablet Screen Replacement, Screen: Schritt 13, Bild 2 von 3 The Sharper Image Literati Tablet Screen Replacement, Screen: Schritt 13, Bild 3 von 3
    • Unravel the screen from the silver backing.
  14. The Sharper Image Literati Tablet Screen Replacement: Schritt 14, Bild 1 von 1
    • Unclip JIF clip and remove ribbin cable.
Abschluss
Spencer Dodder
560 Reputation
4 Anleitungen geschrieben
IUPUI, Team S5-G4, Baechle Spring 2018 Mitglied von IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 280
