Einleitung
Use this guide to replace an old or faulty battery and revitalize your ThinkPad. If your battery is swollen, take appropriate precautions.
Was du brauchst
Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
Insert an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the case, pushing inward to release the clips securing the lower case. You should feel and hear the clip pop free.
When all the clips have been released, you should be able to easily remove the lower case.
Use a spudger or other plastic tool to push the battery connector in the direction of the arrow, removing it from its socket.
Eine weitere Person hat diese Anleitung absolviert.
