Einleitung
The PlayStation Action Buttons are the x, square, circle, and triangle buttons. They are responsible for camera adjustments and other various actions.
Was du brauchst
Remove the five 15 mm J1 JIS head screws from the front of the throttle.
Remove exterior panel from the throttle by using your hands to gently pull the panel away.
Once the black plastic cover is removed, push the buttons inward from the outside of the device.
Remove the two 6 mm J1 JIS head screws that are attached to the tan plastic cover.
Once the black panel is disconnected, push the triangle button inward from the outside of the exterior panel.
Ein Kommentar
Very well presented. Just one question - if one of these buttons (or rather the switch that it activates) has broken, how do you fix it? Where can you get a replacement part if that is what is needed?
