Zum Hauptinhalt wechseln
Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement
Was du brauchst
  1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: Schritt 2, Bild 1 von 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: Schritt 2, Bild 2 von 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: Schritt 2, Bild 3 von 3
    • Use a flat punch tool and a hammer to tap the groove pin from left to right out of the valve handle.
  3. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: Schritt 3, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: Schritt 3, Bild 2 von 2
    • Remove the valve handle from the cam base.
    • During reassembly, apply grease to the cam base before reattaching the valve handle.
  4. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: Schritt 4, Bild 1 von 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: Schritt 4, Bild 2 von 3 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: Schritt 4, Bild 3 von 3
    • Remove the cam base.
  5. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: Schritt 5, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: Schritt 5, Bild 2 von 2
    • Use a 13/16" wrench, or an adjustable wrench, to loosen the bypass valve assembly.
    • Rotate the wrench counterclockwise.
  6. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: Schritt 6, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: Schritt 6, Bild 2 von 2
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alex Diaz-Kokaisl
125.100 Reputation
582 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 24
Insgesamt: 489
