Einleitung
Use this guide to replace the outlet valve in your Titan Elite 3000 High Pressure Airless Sprayer.
Was du brauchst
Turn off and unplug the sprayer.
Lay the sprayer down horizontally before continuing.
Use a 22 mm wrench to loosen and remove the outlet valve.
Use a pick tool to remove the plastic washer from the outlet valve's recess.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
