Einleitung
Use this guide to replace the regulator assembly in your Titan Elite 3000 High Pressure Airless Sprayer.
Was du brauchst
Turn off and unplug the sprayer.
Lay the sprayer down horizontally before continuing.
Use a pick tool to scrape the red paint from the side of the pressure control knob.
Use a flathead screwdriver to pry and remove the clip securing the stop sleeve.
Use an adjustable wrench to remove the regulator assembly.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
