Zum Hauptinhalt wechseln
Tivax MiTraveler 10Q-8 Battery Replacement
Was du brauchst
  1. Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: Schritt 1, Bild 1 von 2 Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 2, Bild 1 von 1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 4, Bild 1 von 1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 5, Bild 1 von 2 Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 5, Bild 2 von 2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 6, Bild 1 von 2 Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 6, Bild 2 von 2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Battery Replacement, Battery: Schritt 7, Bild 1 von 1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 8, Bild 1 von 1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 9, Bild 1 von 2 Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 9, Bild 2 von 2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 10, Bild 1 von 3 Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 10, Bild 2 von 3 Tivax MiTraveler 10Q-8 Battery Replacement: Schritt 10, Bild 3 von 3
    • Once both wires have been desoldered, remove the battery from the device.
Abschluss
Maria
210 Reputation
2 Anleitungen geschrieben
Colorado Springs, Team 4-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-3, Panko Spring 2015
UCCS-PANKO-S15S4G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 835
