Zum Hauptinhalt wechseln
Tivax MiTraveler 10Q-8 Motherboard Replacement
Was du brauchst
  1. Tivax MiTraveler 10Q-8 Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 5, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 6, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Motherboard Replacement, Battery: Schritt 7, Bild 1 von 1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 9, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 10, Bild 1 von 3 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 10, Bild 2 von 3 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Once both wires have been desoldered, remove the battery from the device.
  11. Tivax MiTraveler 10Q-8 Motherboard Replacement, Speaker: Schritt 11, Bild 1 von 1
    • With the face of the device down, locate the speaker in the upper right corner. The black oval shaped object.
    • Make sure Battery has been removed.
  12. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 12, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • A Phillips 3.88 mm screw holds the speaker in place.
    • Use a PH000 screwdriver to remove the screw.
  13. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 13, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
    • The wires will need to be soldered off the motherboard.
    • Locate where both wires are soldered to the motherboard.
    • Review How to Solder Here
  14. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 14, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Work the iron where the red wire is soldered
    • The wire will release from the motherboard.
  15. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 15, Bild 1 von 3 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 15, Bild 2 von 3 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Work the iron where the black wire is soldered.
    • The black wire will release from the motherboard.
    • After both wires have been soldered off, the speaker will release from the device.
  16. Tivax MiTraveler 10Q-8 Motherboard Replacement, Motherboard: Schritt 16, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement, Motherboard: Schritt 16, Bild 2 von 2
    • To remove the black ribbon connector, flip the black portion of the connector upward.
    • Pull on the ribbon to remove from the connector.
    • Make sure battery has been removed.
  17. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 17, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Remove the white ribbon connector from the motherboard.
  18. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 18, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Remove the orange ribbon connector from the motherboard.
  19. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 19, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 19, Bild 2 von 2
    • Locate a 2.88 mm Phillips head screw in the upper right hand corner of the mother board.
    • Use a #00 screw driver with the PH000 screw head to remove the screw.
  20. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 20, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 20, Bild 2 von 2
    • Locate a 2.88 mm Phillips head screw on the lower left hand corner.
    • Use the #00 screw driver with the PH000 screw head to remove the screw.
  21. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 21, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 21, Bild 2 von 2
    • Locate a strip of gold tape, which holds it to the device, on the bottom of the motherboard.
  22. Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 22, Bild 1 von 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: Schritt 22, Bild 2 von 2
    • On the upper right hand corner of the device, a black wire connects to the device and runs to a strip of orange tape.
    • Remove the tape that holds the wire down.
    • Remove the motherboard from the device.
Abschluss
Colorado Springs, Team 4-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-3, Panko Spring 2015
UCCS-PANKO-S15S4G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 321
