Zum Hauptinhalt wechseln
Toilet Flapper Replacement
    1. Toilet Flapper Replacement, Tank Lid: Schritt 1, Bild 1 von 3 Toilet Flapper Replacement, Tank Lid: Schritt 1, Bild 2 von 3 Toilet Flapper Replacement, Tank Lid: Schritt 1, Bild 3 von 3
      • Lift the tank lid up and away from the toilet tank.
      Frag FixBot
      Kommentar hinzufügen
    1. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 1 von 2 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 2 von 2
      • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
      • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
      Frag FixBot
    1. Toilet Flapper Replacement, Draining a Toilet Tank: Schritt 3, Bild 1 von 2 Toilet Flapper Replacement, Draining a Toilet Tank: Schritt 3, Bild 2 von 2
      • Push down the flush lever.
      • Hold the lever down until water stops draining from the tank.
      • A small amount of water will remain in the bottom of the tank.
      • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
      Frag FixBot
    1. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: Schritt 4, Bild 1 von 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: Schritt 4, Bild 2 von 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: Schritt 4, Bild 3 von 3
      • Squeeze open the spring clasp that connects the pull chain to the tank lever.
      • Disconnect the spring clasp from the tank lever.
      Frag FixBot
    1. Toilet Flapper Replacement, Flapper: Schritt 5, Bild 1 von 3 Toilet Flapper Replacement, Flapper: Schritt 5, Bild 2 von 3 Toilet Flapper Replacement, Flapper: Schritt 5, Bild 3 von 3
      • Disconnect the flapper from the posts on each side of the overflow tube.
      • Remove the flapper from the toilet tank.
      Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
123 Mitglieder
50.294 Anleitungen geschrieben
2 Kommentare zur Anleitung
Thank you I needed that
My Mama - Antwort Teilen
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 32
Letzte 7 Tage: 141
Letzte 30 Tage: 640
Insgesamt: 19,596
