Einleitung
This guide shows how to remove and replace the control valve O-rings on the Toro Log Splitter 22618HD 2019 / LS-922.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Flip the red engine ON/OFF switch to the OFF position.
Use a 3/8 inch socket to remove the three bolts securing the control valve to the control valve bracket.
Use a 9/16 inch socket to remove the two bolts securing the control valve bracket to the frame.
Place a bucket underneath the device, below the control valve to catch any hydraulic fluid drips.
Use an adjustable wrench to loosen the nut securing the output hose to the L-fitting on top of the control valve.
Use an adjustable wrench to loosen the nut holding the input hose to the L-fitting on the bottom of the control valve.
Use an adjustable wrench to loosen the nut securing the top L-fitting to the control valve.
Use an adjustable wrench to loosen the nut securing the bottom L-fitting to the control valve.
Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the rear of the control valve.
Use an adjustable wrench to loosen the nut securing the control valve to the cylinder.
Use an adjustable wrench to loosen the nut securing the piston contraction fitting to the control valve.
Use an adjustable wrench to loosen the nut securing the L-fitting to the rear of the control valve.
Use a pick tool to remove the O-ring from the output hose L-fitting, on the side that connects to the control valve.
Use a pick tool to remove the O-ring from the input hose L-fitting, on the side that connects to the control valve.
Use a pick tool to remove the O-ring from the cylinder contraction fitting, on the side that connects to the control valve.
Use a pick tool to remove the O-ring from the cylinder extension hose L-fitting, on the side that connects to the control valve.
