Einleitung
This guide shows how to remove and replace the cylinder and cutting wedge assembly on the Toro Log Splitter 22618HD 2019 / LS-922.
For the amount of hydraulic fluid lost during this procedure, refill the hydraulic fluid tank.
Was du brauchst
Push the control valve lever towards the rear of the device to extend the piston and advance the cutting wedge.
Use an impact wrench with a 3/4 inch socket to loosen the twelve bolts and twelve nuts securing the slide bars to the underside of the cutting wedge.
Flip the red engine ON/OFF switch to the ON position.
Pull the motor's pull-start cable to start the motor.
Use the control valve lever to retract the cutting wedge until it is seated underneath the dislodger bracket.
Place a bucket underneath the device, below the cylinder to catch any hydraulic fluid drips.
Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the side of the cylinder.
Use an adjustable wrench to loosen the nut securing the L-fitting to the side of the cylinder.
Use an adjustable wrench on the L-fitting itself to rotate it to a vertical position with the opening facing down.
Use an adjustable wrench to loosen the nut securing the control valve to the fitting on the cylinder.
Slightly bend the control valve assembly away from the device to create a gap large enough for the fitting to clear.
Remove the fitting.
Shim the cylinder with wood blocks to keep it at its resting height, parallel to the frame.
Pull to remove the two cotter pins securing the large pivot pin.
Shift the cylinder and wedge assembly towards the rear of the device, until it clears the central pin hole.
Support the cylinder and push the assembly towards the rear of the device until it clears the dislodger bracket.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
