Einleitung
This guide shows how to remove and replace the left belt pulley on the Toro Walk Behind Mower 21199HD 2018.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Chock the rear wheels to prevent the mower from rolling during service.
While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
Remove the grass bag.
Use a 3/8-inch socket to remove the four bolts securing the belt guard:
Three 1 inch-long recessed bolts
One 1 1/2 inch-long bolt
Pull the belt guard straight off the front of the mower to remove it.
Loosen, but don't remove, the belt tensioner to give the belt some slack.
Use a flathead screwdriver to pry off the plastic plug cap.
Remove the plug cap.
Use a 3/8 inch socket to remove the four bolts securing the upper belt guide to the pulley.
