Einleitung
A Toshiba Excite 7 tablet's screen replacement can be difficult, but with the correct equipment, and cautious measures, you can finish the repair. This guide will guide you step-by-step through the process of replacing the screen on a Toshiba Excite 7 tablet. The Toshiba Excite 7 tablet features a 7-inch TFT LCD touchscreen display with a resolution of 1024 x 600 pixels for vibrant visuals. If your tablet screen is cracked or broken please refer to these instructions on shattered glass displays before starting this guide. For positive results, make sure you have the appropriate tools and a replacement screen.
Was du brauchst
Remove the back cover.
Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
Remove any black tape from the device.
Keep the tape, you will need to put it back on when you are done.
Unscrew the battery from the device.
The device has 5 screws to remove, keep the screws.
Remove the circuit board by gently coaxing it from the clips located just to the right of the circuit board.
Remove the rubber device from the old screen.
Make sure you keep the rubber device to be install into the new screen.
Repeat other steps in reverse to install replacement screen.
